LCA differences
Old 08-17-2020 | 08:53 PM
Bonez's Avatar
LCA differences
What is the difference with the ACDelco Professional and ACDelco GM OEM lower control arms on Rock auto?
Which is better? Prices are only a buck or 2 different but what to get the better of the 2.
Thanks for any clarification on this.
Old 08-17-2020 | 10:04 PM
I suspect that one is cast AL and one is welded stamped steel. All HHRs came from the factory with cast AL. Most Cobalts came with welded stamped steel.
Old 08-17-2020 | 10:28 PM
The professional has a riveted none greasable ball joint
Old 08-17-2020 | 10:31 PM
Bonez's Avatar
They are both cast, the professional says fits Panel FE1 softride or LT FE3 Sport ride????
I just went with the GM OEM, couldnt find any differences in their listing and the prices were just a few bucks different. I also ordered new bolts. My drivers side is starting to shimmy more during braking so its time to fix it. Going to do both sides
Old 08-17-2020 | 10:34 PM
Fe!=fe3
Old 08-17-2020 | 11:14 PM
Generally, ACDelco professional is lower quality.
Old 08-17-2020 | 11:40 PM
Bonez's Avatar
Ok, glad I ordered the GM OE ones instead...
Old 08-18-2020 | 08:34 AM
I just drilled out the old ball joint rivets and bolted in new Moog ball joints and pressed in a new set of FE5 solid bushings, recycled the aluminum LCA’s
Old original hinge type FE3 bushings also same as FE1
New solid FE5 bushings
New Moog ball joints
Old dry loose original ball joint , 9 years and 130,000 miles
Old 08-18-2020 | 11:52 AM
Bonez's Avatar
Yeah, I plan to rebuild the old ones with MOOG and keep for later if they ever need changed again.
Old 08-20-2020 | 03:00 PM
Bonez's Avatar
My ACDelco's have arrived...
