LCA differences
Old 08-30-2020 | 09:22 PM
  #51
Bonez's Avatar
Originally Posted by Oldblue
You thinking of upgrading to the larger diameter SS non Brembo rotors?
Im not sure, thinking to just stay stock and put new shoes on the rear too, they seem worn ( e brake pulls high ) and braking seems fronts do all the work? Will probly throw new shocks /struts on as well
Old 08-31-2020 | 07:42 AM
  #52
The SS larger rotors only require the SS caliper brackets, you still use your stock calipers.
Have you adjusted the rear shoes and the E brake cable, lately!
Old 08-31-2020 | 03:25 PM
  #53
Bonez's Avatar
Nope, but I did find something... oddly when I opened the hatch the side cover was off? OHHHH LOOKIE !!!!!!!
Old 08-31-2020 | 03:28 PM
  #54
Your trailer harness?
  #55
Bonez's Avatar
yep, apparently theres already one installed.
Old 08-31-2020 | 04:42 PM
  #56
Nice, now adjust those rear brakes
Old 08-31-2020 | 09:10 PM
  #57
Bonez's Avatar
Im going to let the shop do the brakes, replacing front calipers, going to have the system bled as well, new shoes on the rear (if needed) then Ill adjust them at the lever.
Old 09-01-2020 | 07:32 AM
  #58
You adjust the shoes with the the adjuster star wheel first, then the cables, just until 3 clicks when you pull up in the Ebrake.
Old 09-01-2020 | 02:51 PM
  #59
Bonez's Avatar
Yeah I know, but with 200+K on the car I dont know if they were ever replaced so going to have them looked at and replaced if they need to be. My front pads are new but the caliper on drivers side is c ocked from top to bottom so not sure if its from the worn pin that was siezed, I cleaned and lubed it but its still apparently sticking on the pin or something is bent ( bracket maybe ) Im not showing any accidents but not sure whats going on with it? so just going to replace with new.
Old 09-01-2020 | 03:47 PM
  #60
My idea is order front loaded calipers for 2009 SS non Brembo and rotors, that gives you new calipers and brackets and the larger rotors with pads and all hardware
https://www.rockauto.com/en/catalog/...+pad+kit,14204
whopper
"How To" Tutorial Library
165
09-13-2024 10:01 AM
DangerBoy
65
08-04-2023 05:47 PM
mrgreen73
18
08-06-2018 05:54 PM
oldford
29
12-31-2014 06:17 PM
DwHhr2LT
09-29-2012 09:25 AM
