LEDs
Old 11-05-2020, 09:00 PM
Lugji123's Avatar
LEDs
What are the best LEDs for front headlights?
Lugji123 is offline
Old 11-05-2020, 09:20 PM
They change so quickly, I’ve run three and four sided versions, as for brand name they also change quickly, search eBay, the four sided set I have now, were under 50.00
Oldblue is offline
Old 11-06-2020, 07:47 AM
Lonwane's Avatar
I'm running Morimoto 2Stroke H13,s, 5700k. 2 sided and not cheap, but I like them.
Also put Morimoto 2Stroke, 9005's in my fog lights
Stay below 6000k or they project a blue light.
Lonwane is offline
Old 11-06-2020, 04:00 PM
I found the bulbs, on eBay
https://www.ebay.ca/itm/232773187948
Oldblue is offline
Old 11-08-2020, 08:37 PM
jjoverit's Avatar
Led headlights
I've been searching the site and everywhere else for this problem but can't figure it out.. I now have 2 sets of different brands of led headlights that are doing the same thing. So I know it's not the lights. They have sent me decoders to try and load resistors, and they also said to try together. But all i can get to work is the high beams. Even when the car is on low beam setting.They said the highbeam circut is returning to ground? I've tried to change wiring around but that's not working either. I put halogens back in and they work fine. But with the LEDs they stay on high beam. I just read somewhere on a Toyota site about changing the wiring on one bulb is all that needs done. Just looking for some advice. Thank you
jjoverit is offline
Old 11-09-2020, 06:43 AM
Lonwane's Avatar
Did you purchase H13's or H11's?
Mine plugged in and worked with no issues.
Not all brands work with the HHR. Did you check for compatabiblity?
Next step is to notify manufacturer.
Lonwane is offline
Old 11-09-2020, 06:56 AM
Mine were plug and play, no cutting wires or resistors.
Oldblue is offline
Old 11-09-2020, 10:43 AM
tiapetra's Avatar
For those running Led hedlites.
Are the DRLs still working with the Leds?
Causing any other issues?
tiapetra is offline
Old 11-09-2020, 11:00 AM
jjoverit's Avatar
yes they are h13. Been working with manufacturers to try and solve issue. Now I just noticed I have a bad connection on harness. Going to repair tomorrow and go from there.
jjoverit is offline
Old 11-10-2020, 08:32 PM
jjoverit's Avatar
changed connection, still don't work, only low beams. Gave up.
jjoverit is offline
Quick Reply: LEDs
