Linkage, and no crank
Start at the easiest to check, the battery!
does it test good , 12.5 volts or more?
if that is the case , can you take it to your local parts palace and have it load tested?
any indication of engine trouble?
Did anyone mention timing chain broken?
Figure these out first! And if you’re gonna jump start it , connect directly to the battery, not the underhood fuse box!
Does everything else work electrically (power windows, radio, etc)?
If everything else works but the car doesn't crank, I would follow the crank signal:
1) While key is on start, see if there is a crank signal (+12V) at the starter (the thin wire, not the large wire from the battery which is always hot)
2) If no crank signal at starter, then see if there is a crank signal at starter relay in fuse box
3) If no crank signal at relay input, then computer is not sending a start signal (or open connection between computer and relay)
I had a bad starter relay recently that was intermittent.
Steve
Steve
I got in to it a bit, i found a lot of corrosion on a wire in the bcm. I marked the wire on the photo, there was a bit more corrosion on it but I wiped some it off. Is this a clue?
Any idea what this wire is for?
You will need to clean all those connections, do that with the battery disconnected to avoid shorts and sparks and frying your ECM and BCM
next up is the underhood fuse box, see post #9
https://www.chevyhhr.net/forums/prob...tinuing-60806/
