Linkage, and no crank
Start at the easiest to check, the battery!
does it test good , 12.5 volts or more?
if that is the case , can you take it to your local parts palace and have it load tested?
any indication of engine trouble?
Did anyone mention timing chain broken?
Figure these out first! And if you’re gonna jump start it , connect directly to the battery, not the underhood fuse box!
Battery is new, I went to auto zone and had it tested to be safe, supposedly it ran and drove fine. Guy mentioned something about hitting the window button and it wouldn't start after that, he may have been a crack head and not really a reliable witness (lol). He also mentioned it being in anti theft mode but the lock isn't on the dash. I am going to go through all the ground points and look for shorts some time today. I figured at $375 I can't lose even if it is something major. I can always steal parts off of it for my other HHR.
Any previous codes can help narrow down issues, if the code reader wont connect to the ECM that could be bad to begin with.
#26
Have the ignition related recalls been performed? https://www.chevyhhr.net/forums/gm-r...-status-50716/
#29
Some vehicles have safety switches for "Park" being he disconnected the linkage it may be possible he disconnected the safety switch to tow it if the HHR has one, just wonder why he disconnected the linkage to tow anyways? unless he was afraid to drain the battery with it in neutral and key in? Just my thought from vehicles in the past, if that switch is disconnected it wont start. Hopefully someone can verify if the HHR has one and its location..
#30
