Looking for door lock knobs
Old 04-06-2010, 01:27 PM
SmootHHR's Avatar
What exactly did you all use to trim the stem? I wanna be careful not to gouge the door panel. File? Dremel?
SmootHHR is offline
Old 04-06-2010, 01:39 PM
THE BATMAN's Avatar
dremel with a metal cutting wheel, I placed a pc of cardboard with a hole in it to protect the plastic on the door.
It is nice to be able to rest your arm there.
THE BATMAN is offline
Old 04-06-2010, 11:09 PM
Originally Posted by Mike B.
The custom knobs look great but I'm going cheap and simple on this.
Good one Sleeper.
Thanks Mike..
sleeper is offline
Old 04-07-2010, 01:08 PM
asanti's Avatar
Originally Posted by sleeper
Well first you have to un-wind & remove the oem plastic knobs, Very Coarse thread. (rightee-tightee......Lefty loosee)
& in unlock position, trim the threaded stem, I trimmed mine to about level with door panel, Be careful not to bugger up the threads, or it will scrape out the plastic threads in the knobs.. Then wind them back on, Test & if need lower, tighten down more ( but gently)..
That's it..
& if you should bugger the threads, you could just use a glue for knob securement..
So the OEM lock knobs just unscrew (albeit carefully)?! Hmm if it's really that easy then I'll look into trimming mine down this weekend then. Good to know, thanks Sleeper!
Later
Allex
asanti is offline
Old 04-07-2010, 04:49 PM
Take your time.. I had to wrap rubber around my lock knobs to grab them with pliers, to prevent any scarring.. They were pretty tight on there.
sleeper is offline
Condition1
07-28-2010 04:31 PM
budzone
03-12-2010 09:55 PM
dnewmanut
04-25-2007 02:08 PM
kellimaxwell125
Mid Central
12
04-21-2007 09:14 AM
Quick Reply: Looking for door lock knobs
