looking for the plugin for fog lights
ANYone know where to get the plugin for the fog lights as I bought them and not sure where to get the plug in as I was told gm does not have them yet I just need the ends that plug into the bulb for the fog lights
Not sure what your talking about, but does this help at all?
http://www.trademotion.com/partlocat...06&catalogid=2
Harness
AS PER MY G M CATALOGUE YOU NEED TO BUY THE FWD LAMP HARNESS
PART NUMBER 15815654 SELLS FOR $211.00 RETAIL PRICE IN CANADA
I KNOW THIS BECAUSE I AM A PARTS REP IN A GM DEALER
WWW.SURGENORTRUCK.COM
AND I OWN A 2006 WHITE HHR LS
Harness
After Some Research The Fog Lamp Bulb Is Also The Same As A H2 And 3 And If You Have The Main Harness Then You Could Use
Part Number 12101898 Pig Tail Connector Qty Of 2
But Be Careful When You Plice Into Harness As You Will Need To Reprogram The Bcm Module
