looking for spray painting WA913L Sunburst Orange Metallic
Old 08-01-2023 | 02:13 AM
CT09HHR's Avatar
Originally Posted by Oldblue
I think you meant WA913L
https://www.automotivetouchup.com/to...olet/2006/hhr/
I’ve used these guys, the paint matched nicely.
Automotive Touch Up has great service and EXCELLENT color match!!!! I have used them and highly recommend their products!!!
Old 08-02-2023 | 12:25 AM
jimvw's Avatar
I have the sunburst Orange and I ordered the 2006 orange color, it was OK for small scratches, but when I went with the spray can, it didn't match too good. I believe I used the chevy 56, it was a bit lighter than the chevy 802K. but that was over a year ago. the 56 can feels lighter so I think that was the one I used. I strongly suggest using the test spray cards they provide before spraying the whole fender (or door section on my car) The Orange is a hard color to match. If you are doing a complete front fender, you should be OK. I am guessing I have faded paint as it was peeling off on the pass rear door just below the window. Kinfd of like sunlight shining in through a garage window. I know it sat for a few years..
Old 08-02-2023 | 06:59 AM
Jim, what colour code is on the sticker in your glove box?
Old 08-02-2023 | 08:34 AM
jimvw's Avatar
There is the problem.... someone took it upon themselves to remove the sticker from the glovebox. I was able to get an option listing from the serial number, and it says 56U sunburst orange II met
Old 08-02-2023 | 03:24 PM
Ok, now I remember that awhile ago.
Old 09-11-2023 | 09:46 PM
tomasorta's Avatar
I have done this project already, so I cut the bad and rusty part of the fender, I put Bondo, and after the process sander and paint. wasn't perfect for my first time, next time will be better. Thanks so much This forums helps me a lot.
Old 09-11-2023 | 10:11 PM
greg8453's Avatar
Are you happy with it? I've seen worse.
Old 09-11-2023 | 10:32 PM
tomasorta's Avatar
no 100% but yes I am happy, this is my first project, so next will be perfect... the part that I cut was very very bad rust
Old 09-21-2023 | 09:19 AM
desertrat's Avatar
I have bought paint from www.paintscratch.com with great results.
Old 09-21-2023 | 10:29 AM
greg8453's Avatar
I hope you bought and used hardener for the clear coat. I've seen guys not use hardener and it gets marred easily.
SIHHR
04-16-2024 01:07 PM
copper67440
08-09-2011 07:32 PM
Mrs STEP
05-12-2007 10:05 PM
courthousedeb
06-27-2006 12:35 AM
