Loose door issue
Old 04-21-2011, 10:55 AM
Chevy13's Avatar
Loose door issue
I just got a 2008 HHR SS a week ago yesterday. I love everything about it but I have noticed that it seems like the driver door doesnt seem to close as tight as it should. I can actually push it about 1/2 in inch in when it is closed. I couldnt see any way to adjust the striker since it has self adjusting screws. It's not loose enough to cause a leak or create wind noise, just enough to annoy me.
Anyone else have a loose door?
Chevy13 is offline
Old 04-21-2011, 12:50 PM
asanti's Avatar
Take it back to the dealer and have them correct that.
asanti is offline
Old 04-21-2011, 12:58 PM
Chevy13's Avatar
I bought it 2 hours from where I live, and since it's used I don't think a local dealer will mess with it
Chevy13 is offline
Old 04-21-2011, 11:33 PM
Nope, no loose doors here.
I would run a magnet on the door jamb & see if it sticks..Magnets don't stick to thick bondo..
A while back someone bought one that had a door problem.. Turned out to be quikie fixed, from a accident.
Just sayin...
sleeper is offline
Old 04-22-2011, 12:49 AM
Same thought I had sleeper, wonder if it took a shot on that side, check it out with a magnet or at the very least take it to a body shop so they can check for damage. We looked at a ton of HHR's and I've never come across a door that didn't work as it should, ever.
843de is offline
Old 04-22-2011, 12:55 AM
Chevy13-
Not trying to freak you out, just something that should be thoroughly checked. And before too long, since you just got it a week ago..
sleeper is offline
Old 04-22-2011, 01:03 AM
X 2 We're not trying to cry wolf here, but its very concerning and something is most definitely not right.
843de is offline
Old 04-22-2011, 06:34 AM
Chevy13's Avatar
It's not really noticeable at all. I think loose was a bad term to use. It doesn't rattle or anything. It just doest get as snug as the rest. I will look into it more though. Thanks guys!
Chevy13 is offline
Old 04-22-2011, 07:22 AM
TrikerDon's Avatar
The striker is adjustable. Being an old ex-body man for
20 years I have never seen a striker you could not adj.
Don
TrikerDon is offline
Old 04-22-2011, 07:32 AM
Chevy13's Avatar
I thought the same thing too. These aren't though. The screws that hold them in are tapered so no matter what, it will align it back to the way it was before. The claw latch might be a little different though, I'm probably going to look in to modifying it this weekend
Chevy13 is offline
Quick Reply: Loose door issue
