Losing oil through exhaust
Old 11-07-2018 | 10:28 AM
If everything in the exhaust path is clean i.e.:O2sensor, tailpipe, spark plugs What proof is there for out the exhaust?
Old 11-07-2018 | 10:37 AM
Ohiocruiser's Avatar
exhaust tip is all oily.
Old 11-07-2018 | 10:41 AM
DrLoch's Avatar
Have you changed the brand oil that you are using?
Old 11-07-2018 | 11:17 AM
no. Mobil1 5w30 since I've bought it with 20k miles.
Old 11-07-2018 | 12:01 PM
My personal experience is that Mobil1 burns away faster than some others. Yes it is the recommended brand, however the spec has been updated. At the time of manufacture there was only one.
Old 11-07-2018 | 04:23 PM
well it was working fine for me for the last 87k miles. Didn't burn or loose a drop untill recently.
Old 11-11-2018 | 07:02 PM
Little update. That was what I notice and replaced today. It is turbo oil drain line. Is that possible for that bend to reduce oil drain enough to damage the turbo?
Old 11-11-2018 | 07:36 PM
Is there any damage from those gear clamps allowing oil to leak ?
Old 11-11-2018 | 07:51 PM
that was upper end closer to the bend. And it was wet. Since there's no oil pressure there, I am guessing it was "flooding' the shaft. Correct?
Old 11-11-2018 | 08:25 PM
Possibly, I suggest replacing the hose and change to better clamps like this style
