Losing oil through exhaust
Old 01-29-2019 | 01:59 PM
  #51
Ohiocruiser's Avatar
Yes. It is oem
Old 01-29-2019 | 09:25 PM
  #52
I agree, the PCV valve block is installed correctly.
Old 01-30-2019 | 10:43 AM
  #53
removed catch can and drove 50 miles. Now I have the same crap ,that I used to drain from catch can ,in the intake pipe!!! Please, can someone explain what is going on here???
Old 01-30-2019 | 10:57 AM
  #54
Maybe the 2 PVC tubes are backwards?
Old 01-30-2019 | 11:12 AM
  #55
what tubes are you talking about? The line that connects valve cover to turbo us just a line. There's no valves in there. There's only one valve in the line that goes from the head to the intake manifold. That valve is good and positioned correctly. Realy confused.
Old 01-30-2019 | 11:54 AM
  #56
Pull the oil dipstick and show us what the oil looks like.
Old 01-30-2019 | 12:14 PM
  #57
The oil is clean, but i changed it 250-300 miles ago. Coolant looks good.
Old 01-30-2019 | 01:20 PM
  #58
Cat Man HHR's Avatar
Originally Posted by Ohiocruiser
What pipe are you showing ?
Is it from turbo to intercooler ?
Old 01-30-2019 | 01:44 PM
  #59
No. It is from air box to turbo
Old 01-30-2019 | 02:29 PM
  #60
If you can take the hose off the front of the turbo and make a temporary catch can for it. Or take it and run it towards the ground. Looking to see if it's from engine or turbo.
