Louvers
Louvers
Has any one punched louvers in their hood? That is what I want to get done, but my question is. Will the louvers allow the elements to mess-up the electronics under the hood? Here in Texas it has rained every other week-end.
Guys that know their business always fab a tray under the louvers to collect rain and it drains out through a hose> It isn"t seen from the outside and keeps everything nice and dry under the hood> I have built a few myself
A good builder will make the trays as stated... A lot of times the trays are made with a flange where it meets the hood that has flexible magnetic material on it like they make temporary signs out of. This allows you to remove the trays for show and on dry days.
I haven't made any with magnetic strips but, I always welded studs so the tray would be held with small knurled nuts and could be removed easily to clean. I have to laugh, you wouldn't believe what you'd find.There's a real nice rubber tape I use to provide a seal.
I don't like it straight across like that I'd rather an V configurations from the front of the hood. How much does it cost to make one with the removable tray, that would be perfect for dry/wet weather and shows? Definitely would help to pull more air through our after market intercoolers and cool the engine bay.
Louvers are usually priced each. Not a simple job, all the sub-structure must be removed from the skin as the louvers are punched from the bottom. The skin is stripped and layout applied on the bottom side then punched and reassembled to frame work. Then the pan or tray is fabbed, hood painted and re-attached to car. Next time you see a nice louver job you may appreciate it a little more.
