"Low FUEL" Message !!!
About 2 gallons. You need to hit the gas station and pick up a jelly donut and a bottle of anything...TO GO!
Last edited by hhrcrafty; 03-12-2008 at 10:26 PM. Reason: I just like living in paradise...
Mine comes on at exactly 50 miles on the 'miles to empty' reading, after that point it stops predicting miles to empty and just tells me 'low fuel' so I haven't gone much further than that, but 2 gallons would be right.
Mine does the same, pg318. It came on during a long trip on the interstate and I had to go another 5 miles until an exit. I ended up putting 16.2 gallons in the HHR. Pretty surprising since that's the size of the tank.
Bottom line is when that message comes on, find the nearest station and fill up!
Mine comes on a lot later than the other GM vehicles I've owned with similar displays or indicator lights. My Impala had a good 4 gallons left in it, the 2500HD (Duramax diesel) has between 3 and 4. I don't take chances, so I usually have it filled up before the warning comes up.
bad03xtreme
03-11-2010 05:15 PM
Jeff®
10-25-2008 11:12 AM
