lower grill
lower grill
Just installede a lower precision grill. My question is this, as you tighten up the two lower brackets the fiberglass that the brackets hold onto bends up, because its flexable-how fa do you take this when snugging up on the brackets? Other than this question it is a pretty easy install.
I have a Precision Billet one and it does the same thing. I just made sure the upper mounts were nice and tight, then tightened the bottom until it just started pulling up the air dam and stopped. It is still nice and tight and I haven't had any problems in the year or so I've had it.
