Lower seats
Lower seats
Has anyone lowered the seats in their HHR? Are there any seats that are lower? SS? I am 5'10 and find myself looking out the top 3 inches of the windshield. Less than 2" head clearance to the sunroof. How do taller drivers manage? It's going to be hard to chop the top.
After a quick look, the raised floor might make this difficult. My seats are leather, in nice shape, so I prefer to keep them. Seats are manual and I don't see a way to adjust them lower, (Without cut and weld.)
Lowered the rear of my drivers seat about 1.5 inches. Made a custom bracket out of some L bar that I bent. Cut out the original drivers side of the seatbar and replaced it with the custom bracket.
Here's one pic. There are some other pics in my gallery of that mod in progress.
I’m 6,5” and just recline my seat back a click or 2 and adjust my seat bottom down. Mind you , I drive a 2LT without the sunroof, but I have driven SS’s with sunroof and I still have headroom.
With a sun roof you lose an inch or 2 of head room. I wear a ball cap about 99 percent of the time, so that's another 2 inches or so. Those 2 factors combined was the reason I decided to lower my seat.
At 5'10'" I didn't have any problems with my head/ball cap touching the headliner with the stock seat height but it was darn close. Decided to lower the seat many years ago. I really like the lower position so much more than stock height.
6’5” ish here, must be more torso than legs because my non-sunroof HHR’s have been fine but with sunroof, gotta slouch. Is there such a thing as a 2010 SS 5-sp PP w/ no sunroof? Wanna trade?
I will eventually get around to lowering both front seats.
lower seats
Trimmed the outer interior panel (both sides) for easier access to the bolts. Yes, the console needs to be removed for access to the nuts/studs under it where the seat bar bolts down.
Not sure how you plan to get an inch out of the front frame. The "hooks" on the front bracket can't be put any lower. The only way would be to cut out some of the floor frame and reweld it lower. Don't think that would be advisable since it is part of the floor pan frame and structural integrity may be affected.
FYI. If you do lower just the back part, those 'hooks" have to be ground down some to let the seat lean back to the new, lower position.
Had the seat in and out at least a dozen times while test fitting and making adjustments.
