Lucas Fuel injector Cleaner???
Old 05-24-2009, 08:53 PM
xzombiex66's Avatar
Has anyone used it on their HHR? I went to auto zone and they gave me a couple bottles of it. Im curious if its ok to use on our motors.
xzombiex66 is offline
Old 05-25-2009, 09:14 AM
saltyfishguy's Avatar
If that is the same as the lucas fuel additive, I used it, didn't hurt anything, or help anything either.
saltyfishguy is offline
Old 05-25-2009, 09:35 AM
catdaddy137's Avatar
lucas
i heard some say that lucas makes good stuff...i've never used the injector cleaner...i've used a bunch of techtron and lots of people say it is good , but i have never seen any results in my vehicles...i see results everytime i put in seafoam...i put it in the gas , not the intake....i don't see how it could clean the injectors by putting it in the intake....if they gave me the lucas , i would put it in....i have never had any additive harm anything , i think it may be just alot of speculation that additives can harm sensors....i could be wrong ,but this is just my experience.
catdaddy137 is offline
Old 05-25-2009, 12:53 PM
urbexHHR's Avatar
I've heard that the only one worth buying is the Chevron Techron... Can't say if it's good or not because I don't really know how to tell if it works. I can't see if parts look cleaner...lol
urbexHHR is offline
Old 05-25-2009, 01:55 PM
09 Panel's Avatar
Redline SL1 works great.
09 Panel is offline
Old 05-25-2009, 03:15 PM
lunchbox's Avatar
yeah, i add it every time i change the fluids and filter. so i cant tell if it helps any, or if its the combination of everything new. but i do hope it's not hurtin anything
lunchbox is offline
Old 05-25-2009, 03:23 PM
mistermike's Avatar
I buy it in gallon jugs and use the recommended 3 Oz / 10 gal in my cars. It improves the lubricity missing in modern overprocessed fuel. It's a good cleaner as a preventative measure. It is not a substitute for Techron or other aggressive solvent based cleaners. If you're already gummed up, this won't fix it, but it will prevent problems if used regularly. One of my cars is a 96 Chevy van with the notorious "spider" injectors that clog if you look at them. No problems so far.
mistermike is offline
Old 07-24-2009, 07:19 PM
Gator 3's Avatar
Stop now!
Listen guys, do not add any kind of cleaner/additives to your fuel system, all it does is move the crap from your tank to you injectors. HHR's are new enough that the fuel system should be fine (unless you use crappy gas), you will want to think about a professional cleaning around 60,000 miles, TeraClean is what my wife's shop uses. Talk to your local repair shop that you can trust. Good Luck!
Gator 3 is offline
Old 07-24-2009, 07:32 PM
Cokeybill's Avatar
X2.
Cokeybill is offline
Old 07-24-2009, 09:07 PM
Brwbier's Avatar
Which brand of fuel do you think does not put cleaners in their fuel. I bet it is a short list. The only one who is helped be additives is the guy selling them. I just don't think they are necessary.
Brwbier
Brwbier is offline
Quick Reply: Lucas Fuel injector Cleaner???
