Manual Transmissions
You have to turn the wheel either to the left or right after you remove the key. It is a safety feature that, IIRC, is required on all vehicles to insure that the vehicle does not roll out into traffic on hills.
Wow, I stand corrected! I just went out and checked and sure enough it does... If you really crank on it and get about 3/4 of a revolution in the counterclockwise (and 1/4 rev in the clockwise direction) mine locks also.
I know I have never turned the wheel that far after I shut the car off. Why would you? If you are goung to turn the wheel when you park on a hill you obviously would do it before you shut he car off so you have power steering while doing so. I have even pushed the car out of the garage while turning the wheel to do so (to lazy to get the keys! ) and never had the column lock on me before.
When I bought mine on 12/26/07, the dealer had 7 2007 manuels, 2 ls models and 5 1lt all equiped the same, 2 black, 2 white, and 1 sport red metallic which I bought. Each had 5200.00 in options which made them like a 2lt but with a manuel trans. I guess manuels are more popular in the south.
on july 30th this year on the way to work-i stopped by my local chevy dealer on behalf of my co-worker mike--to see if they had any hhrs in stock--because a lot of dealers had been runnin out of new cars because of the feeding frenzy that the cluncker deal was causing and he liked the hhr which i was not too familiar with--the salesman the met me at the door said they had 5--- i had been lookin at used cars like 03 elements---the sales dude pointed out a black 5 speed ls----my fav color and i only drive 5 sps cause they r a lot more fun --i tried not to go ga ga over it but--yada yada yada-----4 hrs later i'm driving my new hhr!!!!!!!----4500 off cluncker---4500 off chevy discounts----it was akin to a small miracle-if you r religious--or the luckiest combination of cause and effect if u r not---my friend mike got a nice grey one too-----all i can say after 3 months---is " I FRIKKIN LOVE IT!!!!"
#26
Somewhere on this thread or another, someone referenced a problem shifitng. There were comments that the HHR uses cables rather than solid linkage between the gearshift and the transmission. Anyone know for sure? How reliable are cables vs linkage, and are there any special lubrication requirements for the cable, or is it sealed?
#30
