Mileage @ MPH and RPM
Old 03-29-2008, 12:49 AM
Snoopy's Avatar
Originally Posted by Cyclic Hardover
Now add the loss in numbers due to altitude, If i were around sea level, I'd be at about 26mpg around town
Interesting comment !!! Where are you at in NM? Some of my best mileage was from Winslow, AZ through NM to Amarillo, TX. Something like 34.5 MPG on some really cheap no-name regular unleaded gas (the only non top tier, that I bought).
Middle of summer, A/C all the way (had rain in Albuquerque), cruise control set at 70 MPH.
EDIT..Oh whoop-de-do...just noticed this is my 3000 post.
Snoopy is offline
Old 03-29-2008, 02:50 PM
Cyclic Hardover's Avatar
Oh I'm not saying bad here just that at altitude like this, you have a loss in power and performance. That many unknowingly pick up on. Even the dealers space it out. I have some hobbies which revolves around this kind of thinking.
Remember the old days where you had to have a tune up whenever you moved to another part of the country? Well electronic ignition and computers has taken car of that process but as long as the engine needs the air, if its thinner, it's going to work harder to achieve the same performance.
Albuquerque
Cyclic Hardover is offline
Old 03-29-2008, 03:21 PM
ChevyMgr's Avatar
I myself do not watch fuel economy. I'm not rich, I just don't care about it. I like to drive my vehicles hard and so whats the point. My wife hates for me to drive her Tahoe. She says I treat her baby badly and it's not used to that type of driving.
But here is what GM says about fuel economy. The part in blue basically says all vehicles get different economy at different speeds. Read on then, ride on!
WHAT TO DO: Maximizing Fuel Economy/Minimizing Costs
The best fuel economy possible is the direct result of proper maintenance and good driving habits. Listed below are GM's recommendations to achieve the best mileage possible. The first group are things to consider for your vehicle, while the second are tips relating to your driving habits.
Vehicle Considerations:
• Tire Pressure - One of the major contributors to poor fuel economy are under inflated tires. Tires low on pressure create drag that the vehicle’s powertrain must overcome, wasting dollars in fuel. Always keep your tires inflated to the proper pressure as shown on the vehicle placard. This not only serves to increase gas mileage but cuts down on tire wear, further decreasing your costs per mile.
• Air Filter - A vehicle that has a dirty air filter can’t efficiently draw air into the engine. This restriction forces the engine to expend energy to "breathe" wasting fuel in the process. Change recommendations are found in your vehicle Owner’s Manual.
• Proper Viscosity "Starburst" Rated Oil - Always use the proper viscosity oil in your engine. Oil that has a higher than required viscosity will create more drag on the internal components of the engine, causing more work for it, especially when cold. Each Owner’s Manual contains information on the proper type of oil for your vehicle. Look for the "starburst" symbol on the front of the bottle, and the SM rating on the API circle on the back label. If you are in doubt, stop by your dealer for an oil change, and any other services required. Most current GM vehicles are equipped with oil life monitors to further assist on the "when" to change your oil. (Aveo/Wave/Optra/Epica currently do not have oil life monitors).
Notice: GM Vehicles DO NOT require additional engine oil additives. Some additives may cause harmful effects to the internal seals and additionally void the terms of your vehicles New Car Warranty.
• Top Tier Fuels - Some fuel manufacturers provide gasoline advertised as TOP TIER DETERGENT GASOLINE (Chevron, Conoco, Phillips 66, Shell, Texaco, Entec Stations, MFA Oil Company, 76, Somerset Oil, Aloha Petroleum, Tri-Par Oil Company, QuikTrip, and Kwik Trip) in the U.S. and (Petro-Canada, Chevron, Shell, and Sunoco ) in Canada. These fuels are preferable when and where available. They help to keep your fuel injectors and intake valves free of deposits. Clean engines provide optimal fuel economy, performance and reduced emissions. When Top Tier fuels are not available, consider a bottle of GM Fuel System treatment PLUS, P/N# 88861011 (in Canada, #88861012), at oil change time which will remove intake system and injector deposits. GM does not recommend any other fuel system cleaner.
Important: DO NOT confuse Top Tier Fuels with Higher Octane (Plus/Premium Grade Fuel) commonly sold at most all gas stations. Plus and Premium fuels are required in some high performance GM vehicles. However, they do not necessarily represent higher detergency present in TOP TIER Detergent Gasoline.
Notice: E85 FUELS: Only vehicles designated for use with E85 should use E85 blended fuel. E85 compatibility is designated for vehicles that are certified to run on up to 85% ethanol and 15% gasoline. All other gasoline engines are designed to run on fuel that contains no more than 10% ethanol. Use of fuel containing greater than 10% ethanol in non-E85 designated vehicles can cause driveability issues, service engine soon indicators as well as increased fuel system corrosion. See Corporate Bulletin Number 05-06-04-035C for additional information.
• Use the Recommended Grade (Octane) Fuel
Purchasing higher than required octane fuel is a waste of money. Using higher octane fuels in a vehicle that only required regular unleaded fuel will neither increase performance nor improve gas mileage. In all cases refer to your owners manual and ONLY use the octane rated fuel recommended for your vehicle.
Important: In high performance GM vehicles that DO require Premium (91 octane or higher) fuel, you MUST use fuels of at least this octane. Use of lower octane fuel may result in reduced performance, knocking, and/or permanent engine damage not covered under the terms of the New Vehicle Warranty.
• Check Engine/Service Engine Soon Light - Is the Check Engine/SES light on? When this light is on, the vehicles On-Board diagnostics computer has noticed that something is wrong. GM vehicles have many sensors that the computer uses to both control and sense actual fuel usage. When the computer lights the Check Engine/SES light it has lost some ability to run efficiently. This may result in increased fuel consumption, increased emissions, and/or driveability concerns.
• Spark Plugs - Even though most current GM vehicles have 160,000 km (100,000 mi) service intervals for spark plugs, if your vehicle is at that point in it's life, have the spark plugs changed to assure proper running and continued efficient, trouble free operation. Refer to the applicable Maintenance Schedule for spark plugs service intervals on Chevrolet Aveo, Optra, Epica, Pontiac Vibe, Wave and Saturn Astra.
Changes In Driving Habits:
• Slow Down, Drive Smoothly - Avoid quick/full throttle acceleration from a standstill in town and high cruising speeds on the interstates. While the optimum MPG for highway cruising speed varies from vehicle to vehicle, faster is almost always worse. If your vehicle is equipped with a Driver Information Center that displays Instant Fuel Economy, select that read out and vary your cruising speed while on the highway. The display will change continuously with uphill and downhill sections but you should quickly be able to identify on level ground the speed range that your vehicle does the best in.
• Empty Your Trunk - Avoid leaving unnecessary items in your trunk. It takes power to move increased weight and that means more gasoline consumption and reduced performance. While the change may be slight, multiplied by thousands of miles, it all adds up.
• Avoid Extended Idling - There is no need to idle your engine till it reaches operating temperature. Idling wastes fuel.
• Combine Trips - Your vehicle uses much more fuel when the engine is cold. This is especially true in the winter months when the engine will take the longest to warm up. Combine errands or trips so that the vehicle only needs to warm up once to encompass many different stops.
ChevyMgr is offline
Old 03-29-2008, 08:21 PM
It all adds up.
Drifter.
Fuel Economy - Hypermiling
13
01-18-2018 11:37 AM
Doog47
09-15-2010 04:52 PM
upnorthhhr
06-17-2010 07:11 PM
Lil Cheney
08-22-2008 07:07 PM
chasarch
09-18-2007 11:55 AM
Quick Reply: Mileage @ MPH and RPM
