Milestone
Old 02-12-2013, 08:09 PM
Jeff®'s Avatar
Milestone
Time for a tune?
Jeff® is offline
Old 02-12-2013, 08:10 PM
Time for big turbo, and tune.
SS fan is offline
Old 02-13-2013, 10:20 AM
IgottaWoody's Avatar
Last time I hit a Milestone it ripped out the oil pan........just sayin..
coming up rapidly on the 70 mark,,but then the 5 yr side is fixin to end in may....in which case your is too..so your completely run out now....
IgottaWoody is offline
Old 02-13-2013, 01:00 PM
solman98's Avatar
68 MPH and only 2050 RPM's.... That's pretty good.
OH, and bye bye warranty......
solman98 is offline
Old 02-14-2013, 09:44 AM
Deke40's Avatar
Noticed that also as my 09 2.4 auto pulls 2600RPMs at 70MPH.
Deke40 is offline
Old 02-14-2013, 12:44 PM
bigjacksauto's Avatar
Thats one of the nice things with the ss's the rpms are lower due to the gearing.
bigjacksauto is offline
Old 02-14-2013, 12:56 PM
solman98's Avatar
What gearing are the SS's using? I know the LS/LT manuals use a 4.17 and the auto's use either a 3.91 or a 3.26(?) depending on year and if it's a panel. The 4.17 & 3.91 are pretty low already. So for the SS to turn that low, it must use higher gearing, not lower.
solman98 is offline
Old 02-14-2013, 05:25 PM
My SS has a 4.05(FQ7 RPO code). Turns about 2900 at 70mph.
If the OP's is an automatic, he most likely eased up on the throttle when taking the picture, thus the lower RPM's noted.
firemangeorge is offline
Old 02-15-2013, 10:38 AM
2900? Somewhere around 23-25 in my SS..dont remember exactly,65 is just over 2000...anyways..if your rpms are dropping off when lifting then your TQ isnt locked up..when it is locked up your running direct drive like a clutch...also the final ratio is different between the auto/stick too, meaning theres more to it then just diff gears.. final trans gearing plays in there
Old 02-15-2013, 11:51 AM
ChevyMgr's Avatar
Yes it's time for a tune-up (plugs), to answer your question.
ChevyMgr is offline
Quick Reply: Milestone
