Missing something?
Old 07-15-2010 | 07:04 AM
solman98's Avatar
Originally Posted by sleeper
Joe-
In the pic I borrowed, the bracket bolted to inner fender is for the brake line..
The hook thru the strut plate is just helping hold back the front inner fender. He was adding horns.. Sorry about the confusion..
When I first saw the hook, I looked at a photo I had and no hook. But it did look like a brake line so I just went outside and reached around the tire, boom there it was.
Old 07-15-2010 | 11:51 PM
Understood Joe.. I looked at my ride too..
What I find frustrating is OP asked his question, got replies & not responding to his findings..
Old 07-16-2010 | 07:11 AM
bowtieboy68's Avatar
The 'gromett' or in your case a plug, would be where the ABS wires would come thru (Least on mine they do)...
Yours does NOT have ABS, does it ?
& is your brake line hanging or not ?? Inquiruing minds need to know..
Joe-
nope, no ABS, so I assume it's just a factory 'die' that wasn't used?
Old 07-16-2010 | 11:34 AM
Figured that, but IS your brake line supported or not ? You have to have a brake line..
What does the other side look like ?
Old 07-16-2010 | 05:14 PM
ok, drivers side is just like passenger side with the exception that it doesn't look like anything was ever mounted there.
as far as the brake lines, i'll have to turn the wheels to the side to see, but i don't recall (when i had them off) that it looked like they were flopping loose
Old 07-17-2010 | 01:13 AM
Thank You, Good luck..
Evad
2.0L Performance Tech
19
01-19-2013 10:37 PM
THE BATMAN
03-29-2012 12:16 AM
drummerboy0088
12-02-2011 07:03 PM
Mike Fortin
08-08-2011 10:39 AM
foolmoon_design
07-25-2010 12:43 AM
