My thoughts on my 2007 HHR (so far)
Old 03-15-2007 | 04:11 PM
  #81
Black Rose's Avatar
Originally Posted by Docwylie
Question for you veteran HHR's (those without an ax to grind, that is) - what do you recommend? Having RB's installed? Having splash/stone guards installed? Coating the fenders with plastic?
Yes
My HHR currently does not have RBs or splash guards on them, but I have bought them (just waiting for the weather to warm up). My HHR came with the rear fender protector (yours should have them as well).
I've had mine for 5 months now and have put about 6,000 miles on it. I examined the paint after I took it through a car wash the other night and the only "sandblasting" I have is on the rear fender protectors.
I bought the RBs so that I would avoid having the sandblasting issue that the original poster has.
As for the splash guards, others have posted that they really don't protect that well since the front ones do not go low enough. I'm only installing them for the cosmetic effect.
After I install the RBs and splash guards, I am still leaving the rear fender protectors on as added protection.
Old 03-15-2007 | 04:12 PM
  #82
Snoopy's Avatar
Your choice Doc.....
But, in most instances, the splash guards alone will not resolve the issue. Adding clear plastic, probably. But, how much and how high up do you wish to go?? After all installation and materials, the cost will probably approach the running board cost.....unless you install yourself, which is a real B***H.
If you wish not to pay the dealer for the boards and installation, check around for the boards and install yourself. Not hard. There is a running board install, with pictures, on this forum by one of our female members.
Obviously my vote is for the boards.
Old 03-15-2007 | 05:36 PM
  #83
Docwylie's Avatar
Thanks
Thanks for the insight, Black Rose and Snoopy. I had the same thought about the effectiveness of the splash guards when I looked at some pics of them. After I left my post, I went out and looked at my car and noticed the rear protectors for the first time. Funny how you miss stuff sometines. Anyway...looks like I'll be calling my dealer to inquire about getting RB's installed.
Thanks again-
Doc
Old 03-16-2007 | 10:53 AM
  #84
454Taylor's Avatar
Wise idea, do it before any damage occurs. I firmly believe running boards need to be STANDARD equipment on the HHR. Some climates are worse than others. Damage will eventually occur without them no matter where you drive..
Old 03-16-2007 | 10:55 AM
  #85
I fully agree with you on this....
BeanWagon
12-16-2008 11:33 AM
stephenm
08-12-2008 05:47 PM
groovielou
22
10-28-2007 12:11 AM
bhoyer
Tires & Wheels
14
07-24-2007 10:38 PM
Angelo
09-28-2006 09:49 AM
