Need advice
Old 04-11-2023 | 12:32 PM
Will1861's Avatar
not a good pic...can't get anything in there lol
But you can kind of see the build up there. My concern is the where the wires go into the plug...if that's all gunked up and causing the sensor to act funny
Old 04-11-2023 | 03:21 PM
Probably got goo in the connector.
Old 04-11-2023 | 03:25 PM
Originally Posted by Will1861
Ok....so going on the premise that the oil leak has screwed up the crank sensor....I can see the plug, it's pretty nasty...is there a way to clean that mess up...so it doesn't just mess up a new sensor
Your choice of cleaner. I have used Green, Purple and Fantastik or engine cleaner; followed with a water rinse.
Old 04-11-2023 | 03:37 PM
Will1861's Avatar
what's the secret....I can't get it to come loose to save my life lol
Old 04-11-2023 | 03:38 PM
Will1861's Avatar
Sorry....I didn't think the first one posted
Old 04-11-2023 | 03:55 PM
PulpFriction's Avatar
Probably not the crank sensor. Hardly ever is. Could be, but eliminate everything else first.
Trying to understand the problem. First, just to make sure, is this an automatic or manual?
When the tach rpm's surge, do you hear the engine speed rise too?
Old 04-11-2023 | 04:59 PM
There is usually a "catch lever" on the pigtail side.
If you replace it, you should have the variation relearned. That requires a computer.
Old 04-11-2023 | 06:14 PM
Will1861's Avatar
Thank you everyone. It's all back together, seems to be running fine. I guess time will tell...
Old 04-11-2023 | 07:45 PM
greg8453's Avatar
I would not worry about the gunk on the connectors. Some think of it as a sealant that keeps moisture out. They are built with insulation that is best left alone. You open it up and you are forced to clean it up good and may not be near as good as it was.
Old 04-11-2023 | 09:17 PM
However, oil is not a good conductor. If it gets between contact surfaces the TTL level signals can get lost or mangled.
One member found that oil migrated UP the harness to the ECM connector and caused a lot of problems.
The insulation on the wires can deteriorate when in contact with oil.
nicolade1976
07-21-2022 04:33 PM
Bruce Donaldson
09-01-2021 06:35 PM
John Mark Smith
Maintenance and Upkeep
08-18-2019 10:02 PM
mrmarkuSS
09-29-2017 07:45 PM
RicT
09-10-2012 06:30 PM
