Need vacuum for gauge
Old 04-04-2006 | 11:10 PM
Lee3333's Avatar
Any ideas on a good spot for a 't' fitting to get vacuum for a vacuum gauge? On my last car I did it by the PCV valve. I thought I found it in the front of the engine (1/2 hose) but when I tried it, there was no vacuum there. I have not taken off the air filter yet, but I guess it would be under it somewhere. Unfortunately, the top cover does not come off very easily.
Old 04-05-2006 | 06:41 AM
WHITEHHR1's Avatar
Hose
there is a hose at the back of the throttle body that goes to the evap
emission solenoid valve that should do the trick
Old 04-06-2006 | 06:30 PM
Lee3333's Avatar
Thanks I'll give it a try. I guess I will need to remove the air cleaner cover.
Old 04-06-2006 | 10:12 PM
SIHHR's Avatar
What is the purpose for doing this? I'm confused sorry
Old 04-07-2006 | 01:57 AM
SoCalHHR's Avatar
We all knew that.
Old 04-07-2006 | 11:52 PM
Lee3333's Avatar
Vacuum gauges can be used to show any engine problems, as well as gas milage. When you step on the gas, the vacuum goes down. By trying to keep it high, you get better fuel economy. Erradic (spelling) vacuum means either a leak somewhere in the engine or some other problem. With forced induction (turbo or supercharge) you go past 0 vacuum and into positive pressure, or boost.
Old 04-08-2006 | 01:05 AM
SoCalHHR's Avatar
That is all true.
Old 04-08-2006 | 10:26 AM
Lee3333's Avatar
Plus it looks neat when the needle moves as you step on the gas
Old 04-08-2006 | 11:20 AM
O6ChevyHHR's Avatar
you got that right!
Old 04-08-2006 | 12:03 PM
captain howdy's Avatar
I have to say I don't really see the point of putting a vacuum gauge on a non boosted EFI engine.
Quick Reply: Need vacuum for gauge
