New rims rubbing... Help!
Old 10-29-2011, 11:54 AM
Mike Fortin's Avatar
Guys I just chaged my rims and in corners I'm getting a rubbing metal on metal sound.
Any ideas??
Mike Fortin is offline
Old 10-29-2011, 12:10 PM
would help to know what size...
GDZHHR is offline
Old 10-29-2011, 12:14 PM
18's
Old 10-29-2011, 12:18 PM
tmerkle111's Avatar
That size is fine as long as you kept the tire around the same size. I have 20's on mine with no issues. Take the tire off to see if the rim has any marks on it.
tmerkle111 is offline
Old 10-29-2011, 12:24 PM
They are rubbing on the caliper.
Old 10-29-2011, 12:28 PM
tmerkle111's Avatar
To me it sounds as the rim has the wrong offset.
Old 10-29-2011, 12:42 PM
Time for some spacers. 843 gave me a tip to order them here they are on the way from Pa. and made in Germany, should be high quality. Considering what they do, not the spot to get cheep.
http://www.andysautosport.com/chevro...r00909942.html
SS fan is offline
Old 10-29-2011, 02:48 PM
Like I said need info on size...how wide, what's the offset? 18's isn't enough to really help, but it does sound like it's either width or offset. Many, including me are running 18s with no issues. Tire size might be helpful too.
GDZHHR is offline
Old 10-29-2011, 09:17 PM
prod's Avatar
When I put caddie wheels on mine they rubbed the calipers. You need spacers. Dont get any more than 5mm, you can still use the stock studs and nuts.
prod is offline
Old 10-31-2011, 09:52 AM
Spacers is the ticket, sadly the ones I got at PeP Boys are to wide so no go.
I might just grab a few washers from home depot.
In the meantime, I've been driving it and they seem to be wearing in a bit.
Quick Reply: New rims rubbing... Help!
