NEWBIE - Need advice
Back in my wrench turning for a living days I was a big Interstate battery fan. The last 20+ years though it's been mostly Walmart batteries I've bought.
Had good luck with them. Never had one that didn't last at least 5 years. I even had one in my Kubota tractor that lasted 13 years or so !
(OK. Those small batteries for my riding mower were only good for about 2 years but they were only $19.99 for the longest time)
I recently replaced the 10 year old original battery in my SS. Yep, Walmart brand.
I will keep this one checked every 4-6 months or at oil changes too.
The 5 year free replacement warranty included and the raving reviews on various sites were too compelling to try it, and even my neighbor raves about them in his bang-around Jeep Wrangler. He’s got an 11 year old Walmart battery and still starts up every morning for him.
Moog or Prime Choice on eBay, we get a discount from RockAuto.
to inspect the upper motor mount , look thru the oblong hole in the passenger side front wheel well , if the bolt head is lower in that hole , the rubber in the mount is toast. It can make a clunking sound from metal to metal contact
That clunk could be LCA’s rear bushings, sway bar bushings , swaybar end links , loose bolts . You’re gonna have to hands on inspect them .
Sounds to me , LCA’s need replaced first , this will eliminate the rear bushings and the ball joints , if their still OEM they are first suspect
#26
RS clunk
I have same noise(s) you describe and add a whining wheel bearing. I raised and checked many times and minimal looseness in the wheel bearing. The LCA's are aluminum on mine. I am considering replacing the lca components (bushings / ball joint) as I have access to a press and can take a day or two as needed to complete it.
#27
If you are replacing the ball joints and rear LCA bushings then , yes go with Moog K201285 bushings and Moog K80567 ball joints, but only for the FE1 and FE3 suspensions , the rear bushings can be used in the FE5 LCA’s, but definitely not the ball joints as the stub is a smaller diameter, which causes problems in the FE5 steering knuckle.
