No Auto Start w/ my automatic
Old 06-29-2007 | 10:07 AM
krishaynes's Avatar
Originally Posted by Snoopy
Reread post # 2. He states, which is true, vehicles built for the rental fleets had the remote start delete option.
Chizzer.....if I remember correctly HHR's with the automatic trans. and built for Canada, did not automatically come with the remote start. You had to elect it as an option. But, look on the bright side.....you got running boards (standard in Canada on 07's).
May be wrong, however.
You're right! No standard Autostart for us Canucks , but we do get the running boards!
...does that mean we get to brag or should we hang our heads in shame?
Old 06-29-2007 | 01:50 PM
nfboy's Avatar
Originally Posted by Dave C
Your key should have a small circle with a + in the center just below the black head. That indicates a chip is in the key.
That is for the security system not auto start.
From the manual:
"The key has a transponder in the key head that matches
a decoder in the vehicle’s steering column."
and
"(Remote Vehicle Start): If your vehicle has the
remote vehicle start feature, the remote keyless entry
transmitter will have a button with this symbol on it." (symbol is a circle shaped arrow)
Old 06-29-2007 | 02:14 PM
kdugg_fl's Avatar
From the manual:
and
My transmitter has the button, but it doesn't work. Perhaps I'll try wheelie's little walk through and see if it work.
Old 06-29-2007 | 03:00 PM
kdugg_fl's Avatar
Originally Posted by Wheelie7
Hi There,Ill be the 1st to help you...
When I first got Wheelie (My Blue HHR) from the dealership, the auto start feature was disabled, so the dealer turned it on and Wheelie could start automatically, it could be that your auto start feature has been turned off, and U may need to turn it on..here is how:
1)Turn on our HHR to ON
2) press and hold the little Menu button and the left downward arrow button on the steering wheel for 3 seconds, you should see OIL LIFE RESET on the DIC
3) keep pressing the MENU botton till u see AUTO START on the display. (or something simular to it)
4)press the left arrow botton to turn that feature ON
5)now turn off your HHR and on your key fob, press the LOCK button. (u may want to get out of the car for this part)
6)within 2 seconds of you pressing the Lock button, you must press the little uncompleted circle botton on your key fob, the TOP center button and hold it for 2 seconds
7) Your Beloved HHR should turn ON automatically for you.
HOPE THIS HELPS!!
It worked!! Thanks Wheelie7!
Size:  23.1 KBName:  45F175F10bowingsmileys.gif
File Type: gif
Old 06-29-2007 | 04:28 PM
Wheelie7's Avatar
You are welcome!! ..Wheelie is happy for you!, he is clapping his doors for you!..HEEHEE!
Old 06-29-2007 | 06:02 PM
  #26
Lone Ranger's Avatar
Now, Katie: get out there and freak some people out when they're near your car...
Old 06-29-2007 | 07:50 PM
  #27
svtjoe's Avatar
I usae my autostart everyday.... FL is Hot in the Summer!!!
Old 06-29-2007 | 10:07 PM
  #28
Alzonie's Avatar
Originally Posted by Chizzer
My remote doesn't even have a button for it. Just lock, unlock, and alarm.
I guess if they can enable that feature on your HHR you'd get a different remote to go with it.
Ian Rome
11-22-2011 02:13 PM
mightymouse
11-22-2011 09:33 AM
cearay
05-27-2009 11:16 PM
REDHHRSS
10-14-2008 12:31 PM
Lone Ranger
07-29-2008 10:09 PM
