No Block Heater on SS?
Not sure if this is the right forum, but just realized (have a pending purchase of a new SS as of yesterday, finalized by Wed.) that I didn't see the option for a block heater for the SS, as was on there for the LS or LT, before I signed the deal.
I guess I just assumed at the SS trim level it was standard, but after more thought today, that that didn't make sense either.
Sure enough, not an option on the SS according to chevrolet.com.
Having never owned a turbocharged engine before, I assume the tubro technology of the engine doesn't allow for it?
Not a deal breaker, but I live in a climate where that would be used 4 or 5 days a year.
So is there a technical reason, or just GM not seeing a need to add it to that engine? Furthermore, if its the latter, can it be added at a dealer after the fact?
Good eye! When you are talking to them again would you find out why not and/or how much for a dealer install, I would think they should be at least optional in Canada. The 2.0 L design comes from Europe (I think) and was previously used in the Sky (might not need a block heater as it is not a winter type car) but that engine is going in the Cobalt SS and they will should need them.
Just had a thought but what is the main purpose of a block heater? Is it to keep the oil from getting too thick which would make it harder to flow thru the engine and possibly cause damage? If that is the primary reason then perhaps block heaters aren't needed with SS's since they come/require mobil one synthetic oil which doesn't suffer from low temperature issues?
From the mobil one website:
"Excellent high- and low-temperature performance.
* Pours at temperatures as low as -53ºF and protects at oil temperatures as high as 400ºF. "
How far up are you? I had them on my cars when I lived in Alaska.. Heater blankets, Electric dipsticks and the whole thing.
Update:
Picked up my SS today, and the salesman said that he doesn't think there is room in the compartment, as the turbocharger is attached to the back of the block, where the block heater would usually be.
What about the electric dipstick. plus the fact if your that far up, we usually ran straight 5 weight oil along with it.
