observations and a question or two; A/C and wiper fluid
Old 05-22-2006 | 04:08 PM
Skatetheglobe's Avatar
In South Florida we just switch it to High and Thank God for the man that invented A/C..
Old 05-22-2006 | 05:03 PM
BamaHHR's Avatar
I, too, tested it on the way home. There was no difference between recirculating with the a/c button on and recirculating with the a/c button off. Learned something today!
(It's only 96 today...wish the a/c in the house worked as well as the a/c in the car!)
Old 05-22-2006 | 05:37 PM
Low Tone's Avatar
Originally Posted by MikeX
So for my experiment you say do the following:
It's 90 deg outside today, and you say leave the windows up, recirc on, and no A/C light on (do not push the button). The hypothesis is that I will feel cooler air than 90 deg blowing out the vents. Is that correct?
Yup.
Old 05-22-2006 | 07:11 PM
angeleyez0072's Avatar
I got my HHR in April, I think we've had one "warm" day (70 degrees i think)since then and i did notice when i had the air on in the cold position (not the a/c) that it was much cooler than the outside. I'd go try it out as well but it has been raining here for 10 days at least, it's 45 degrees and i still need to remote start to warm up the inside in the morning!
Old 05-22-2006 | 09:20 PM
dbarberaz's Avatar
As to the first part, it's not physically possible to blow cooler air than the outside temp without some mechanical system being involved, so, with all due respect, I don't think I believe your claim. I would sugest a measurement of temperature is in order.
Well I belive his claim. I live in Az and have only used the ac a couple of times. Also would suggest you give it a try if you doubt us. I could tell you I took temps and it is true, but would that make anyones claim beliveable? No you would still need to try it before you belived it.
Old 05-22-2006 | 09:29 PM
  #26
SoCalHHR's Avatar
I'd like to see a dyno chart to confirm...
Old 05-22-2006 | 09:31 PM
  #27
cyberone3's Avatar
Cool
the HHR turn the ac compresser on an off while you drive to keep the compresser and seals lube so it doesn't fail before its time, could if be the left over compresser from the ac that we are feeling like when you turn you ac on for awhile then turn it off its still cold for awhile then warms up but ours it kicking on and off for most of the time we drive!
Old 05-22-2006 | 09:35 PM
  #28
captain howdy's Avatar
You'll have to settle for a "seat of your pants dyno".
Old 05-22-2006 | 09:43 PM
  #29
MikeX's Avatar
If you look back at page #2 of this thread you will see that I did try it on my way home this afternoon and found the claim to be true.
Old 05-22-2006 | 10:18 PM
  #30
Low Tone's Avatar
WooHoo!
Were not nuts after all!!
(Well at least on this issue..... )
Quick Reply: observations and a question or two; A/C and wiper fluid
