Odd rubber bumper on hood
Old 10-06-2011 | 09:52 AM
jaskispyder's Avatar
I was washing the HHR and I popped the hood to get the tops of the fenders and as I was releasing the latch on the hood a small rubber bumper fell to the ground. It is about 3/4" long and triangler shaped. I found that it mounts to the underside of the hood, at the center of the grill. It was held on by adhesive. A pretty dumb design, but I took some 3M emblem tape and stuck it back on. It seems to hit the front bumper when the hood is closed. Anyone else notice this or have it fall off. I think I would rather have a different design.. maybe the type that mounts within a hole and is round. Anyway... looking for some feedback.
Old 10-06-2011 | 02:44 PM
well, from the looks of it, this bumper is called an overslam bumper. I will look at the HHR to see if there is another bumper under the hood, but otherwise, that is the name the parts catalog gives it.. and it is $7! huh?
Old 10-06-2011 | 05:51 PM
"Plumber's Goop tm" is a great way to make things stick on to each other.
Old 10-06-2011 | 09:43 PM
BlackknighT's Avatar
Same stuff I use-sticks when you need it but can be removed later. I use a dab of it on each of my door pull area to hold the rubber screw cover in place and not vaccuum it up!
Old 10-07-2011 | 02:12 PM
nacademus's Avatar
Post a photo.
Lawagz
Maintenance and Upkeep
12-18-2014 06:21 PM
Fred08
04-12-2008 11:36 AM
da_loca
19
11-24-2006 02:45 PM
