Oil Catch Can Install November 2017
Old 05-09-2018 | 08:52 AM
gio89kid's Avatar
Here is something I just found online.
Using water as a filter!
Apparently if you have a can that has an inlet at the bottom and an out put at the top you fill the can with water until it covers the inlet. When the car is running it pulls the air though the water and anything in the air instantly condenses in the water leaving the bubbling clean air to travel to the output.
I will not be doing this as I don’t want water accidently sucked into the engine or traveling back into the valve cover, but pretty interesting idea.
Old 05-09-2018 | 06:35 PM
I’m thinking , sucking water into the engine, no not a great idea.
Old 05-09-2018 | 08:05 PM
Yes, water is what we're taking out of the air stream, don't want to put more in.
Dbeluscak
2.0L Performance Tech
412
04-27-2022 06:26 PM
Cat Man HHR
"How To" Tutorial Library
12-06-2018 06:49 PM
Cat Man HHR
07-28-2015 06:48 PM
bigjacksauto
12
06-26-2013 07:36 PM
hhr_2009
2.2L Performance Tech
0
10-21-2010 06:11 AM
Quick Reply: Oil Catch Can Install November 2017
