Oil change
Old 11-23-2006 | 12:55 PM
vettman's Avatar
Oil change
I plan to do my next oil change and was wondering if the drain plug is located in a position that will allow the pan to drain with the front of the car on ramps, or does the car need to be level. Thanks
Old 11-23-2006 | 01:03 PM
endeavorc's Avatar
The drain plug is in the rearward position of the oil pan. You will have no problems with the vehicle on ramps.
Old 11-23-2006 | 03:35 PM
vettman's Avatar
Thanks
Old 11-23-2006 | 03:48 PM
Black Rose's Avatar
I haven't crawled under my HHR yet.
Is there enough clearance between the pan and other components to install something like a Fumoto drain plug valve?
solman98
Maintenance and Upkeep
255
08-08-2014 08:39 AM
JWA
16
06-21-2014 01:16 PM
badassbowtie
23
05-12-2013 03:01 PM
SIHHR
02-14-2007 08:35 PM
