Oil Myth
#41
#42
The contact or friction areas are NOT aluminum. Most importantly, the block cylinders are sleeved with Steel and the rings are ferrous as well.
#44
yep yep... that s how they work... "chips light" "feather four" "in what order?"
#45
The difference I could tell was that the engine didn't seem as "free" with the heavier weight. Basically what Offy mentioned, close tolerance + heavier oil = more resistance for the pistons, crank and so on.
