oil pan question
oil pan question
07 2.2 ls auto
i searched good and yahoo but i cant find the part number nor at aap either..
does anyone know what gasket our oil pans take?
when i look up gasket it shows just the tranny pan
and from another posting - "Apply a 2 mm bead of sealant (1) GM PN 12346286 (Canadian PN 10953472) or equivalent, around the perimeter of the oil pan and the oil suction port opening. DO NOT over apply the sealant. More than a 2 mm bead is not required. Tighten the bolts to 25 N.m (18 lb ft). "
