Ooga anyone?
Old 03-30-2008, 07:04 AM
karen1953's Avatar
Thanks for Sharing Remford, Where are you going to install it?
Mine is behind the tire well, in place of the orignal.
karen1953 is offline
Old 03-30-2008, 07:21 AM
Ratzilla's Avatar
Originally Posted by Remford
glad you found what you were in search of and Thank you for sharing with the HHRs here as we love to pass on what we can.
curtsy
Elle'
Ratzilla is offline
Old 03-30-2008, 10:01 AM
AJochum's Avatar
Ooga Horn
I have an original Ooga Horn made in the late '40s or '50. It uses no electric, but gets its results from manifold vaccuum. It was manufactured by Yoder Mfg. out of California. It's about 5 inches high by 7 inches long and has a cone or horn shaped end to shoot out the sound. You pull a lever which releases the pressure.
I had always planned on hooking it up to my '54 Ford someday, but perhaps the HHR would be deserving of it, based upon its '40s roots.
You might find one on e-bay, but I suspect you'll pay dearly. If you ever wanted one, I go to Carlisle and Hershey, along with other swap meets, and I'd be glad to look around for you. Let me know... I could forward pictures if necessary.
AJochum is offline
Old 04-01-2008, 12:18 PM
steelwoolghandi's Avatar
I bought a 12 Volt "Oooga" Horn at Harbor Freight and plan to hook it up this weekend. Does anyone have information on disconecting the existing horn and hooking up another horn in its place?
steelwoolghandi is offline
Old 04-01-2008, 12:40 PM
karen1953's Avatar
My oogah horn is in the same place as the original WAS.
Used the same wires, only spliced so if I ever need to put the original back I can.
Old 04-02-2008, 11:04 AM
GCarp's Avatar
I mounted mine (JC Whitney special) inside the front bumper using one of the existing holes and an "L" bracket. Wired it to a seperate button.
GCarp is offline
Old 04-02-2008, 09:48 PM
Cool so you use the same wires and when you push the steering wheel horn it works?
