Outside Temp
You should probably take it to the dealship for repair. I think it`s supposed to read in Farenheit.
You change the settings for "American" and metric through the DIC.
Here is the online owners manuals
Online Owners Manual 2006 HHR
Online Owners Manual 2007 HHR
Mine tends to be dead on. A variance of 1 or 2 degrees is not a problem since temps can vary a little in the same general area. So within one city you may get two or three different temps depending on where you are versus where the particular radio station gets their temp info.
While driving around Ottawa tonight, the temp on the DIC ranged anywhere from -19C to -27C.
And I thought it was cold when I woke up and it was 9F.
Mine is usually dead on. As long as it is within 2 degrees +/-, I don't see a problem.
I have the same problem...
There are a few other threads regarding this problem. Here's one of them.
https://www.chevyhhr.net/forums/problems-service-repairs-42/update-outside-air-temp-read-problem-4060/
One thing I thought maybe was happening was residual heat from the sheet metal the sensor was attached to. I reached up in the cavity and pulled it off the mount to let it hang away from any metal parts. The only thing is when I did it, it got really cold out and haven't been able to see if it works or not.
George
George
