P0172 & P0561 after 30 second idle
Old 12-27-2022 | 06:02 AM
superpaige's Avatar
THIS IS DRIVING ME F****** NUTS!!!
If I sit at a traffic light for more than 30 seconds, my traction control light comes on and I get those 2 codes.
I have replaced: spark plugs, fuel injectors, both shift solenoids, air filter, gas cap, evap purge valve … it’s an 06 2.2l LT. Any advice would be so appreciated.
Old 12-27-2022 | 08:10 AM
I would look for a dirty MAF sensor, see if it’s plugged in correctly and firmly.
inspect the exhaust manifold and flex pipe for cracks and air leaks before the first O2 sensor
https://www.obd-codes.com/p0172
I suggest you have the battery load tested, and the charging system tested , your local parts palace should perform these tests free of charge. I’m thinking sitting in a barn for 2 years the battery is dead, any thing under 12.4 volts is a dead battery!
https://www.obd-codes.com/p0561
Old 12-27-2022 | 08:43 AM
FYI.
The OP has a post in another thread where they say this car has wiring problems. AKA mice have been chewing on the wiring.
Old 12-27-2022 | 09:47 AM
Yes, I read that, so they might have knawed on the harness near the MAF
Old 12-27-2022 | 10:16 AM
P0561 is basically from the Alternator control wire, loose or chewed. That could cause the P0172.
Old 12-27-2022 | 06:10 PM
superpaige's Avatar
FYI.
Well, the car was in the barn more like 10 years, not 2 . I’ve cleaned the MAF several times, no improvement. BUT, where the connector wire connects to the big wad of other wires…the wires DO seem flimsy to me. Where would I find the alternator wire?
Old 12-27-2022 | 06:11 PM
superpaige's Avatar
Oh! And the battery is only maybe 2 months old.
Old 12-27-2022 | 06:27 PM
But what was the CCA and static voltage and running voltage?
Alternator wire runs from the starter to the alternator
Old 12-27-2022 | 08:12 PM
Wouldn't it be the smaller wire, it snaps into the alternator?
Old 12-27-2022 | 08:23 PM
That is the one I meant.
