P060?
Old 06-07-2021, 11:55 PM
MN Murph's Avatar
P060?
This started about 200 miles ago, give or take 100, about a week ago:
  1. The fan stays on after the vehicle's shut off... for about 10 minutes, give or take 5? I didn't think much of it because of this heat wave for the past week;
  2. The temp gauge on the dash is sitting a little low, a couple marks below halfway...during a heat 🔥 wave of weather;
  3. I pulled a code and then cleared it (it popped up right after they ghosted up my vehicle...) and I maybe wrote it down incorrectly because the o'reilly's said they couldn't find the code, which I wrote down as p060. So, I'll wait for the CEL to pop up again and recheck it;
  4. I was low on coolant...during a heat wave. Coolant added. I'll hope it feels better tomorrow and get it in for all that asap.
MN Murph is offline
Old 06-08-2021, 06:26 AM
If coolant is low, in the reservoir, check at the filler neck under the rad filler cap. If there’s air there you need to burp the coolant.
that p060 isn’t a valid code.
Oldblue is offline
Old 06-08-2021, 08:24 AM
There is a digit missing from the code and maybe the letter is wrong. Error codes are in hex, so there might be a letter at the end. like P060D.
The fan should only run after shutdown if the temp is over 240F.
Something is wrong.
donbrew is offline
Old 06-08-2021, 08:33 AM
  1. The fan stays on after the vehicle's shut off... for about 10 minutes, give or take 5? I didn't think much of it because of this heat wave for the past week; It's running above normal temp if the fan stays on after shutdown.
  2. The temp gauge on the dash is sitting a little low, a couple marks below halfway...during a heat 🔥 wave of weather; Temp gauge on the dash is not very accurate on these cars. Get the actual temp from the digital gauge in the DIC.
  3. I pulled a code and then cleared it (it popped up right after they ghosted up my vehicle...) and I maybe wrote it down incorrectly because the o'reilly's said they couldn't find the code, which I wrote down as p060. So, I'll wait for the CEL to pop up again and recheck it; Yes. You probably wrote it down wrong.
  4. I was low on coolant...during a heat wave. Coolant added. I'll hope it feels better tomorrow and get it in for all that asap. Coolant doesn't just disappear or evaporate. You have a leak or it's burning it out the tailpipe.
firemangeorge is offline
Old 06-08-2021, 08:36 AM
You should use the DIC to monitor the coolant temperature, the guage is not accurate.
ghosted up my vehicle? What are you talking about?
RJ_RS_SS_350 is offline
Old 06-08-2021, 08:40 AM
Do you mean 240*?
Old 06-08-2021, 09:29 AM
I guess either the software is messing with us or 2 of us did the same thing at the same time.
The original was tacked onto the end of a totally unrelated thread.
donbrew is offline
Old 06-08-2021, 09:51 AM
Red face
Do you mean 240*?
Don's post that I was responding to is just gone... Not showing as deleted, I don't see it in the list of Don's recent posts... Just gone.
Old 06-08-2021, 10:28 AM
You mean post #3 ? I still see it but looks like the 140 got edited to 240.
Yeah. This whole thread went "wacko" for a time.
Old 06-08-2021, 11:18 AM
Somehow the 2 posts that I removed from the original thread got put into 2 new threads with the same title. I merged the 2 threads and did edit my misteak.
Now, back to your usual programming.
donbrew is offline
Quick Reply: P060?
