P060?
P060?
This started about 200 miles ago, give or take 100, about a week ago:
- The fan stays on after the vehicle's shut off... for about 10 minutes, give or take 5? I didn't think much of it because of this heat wave for the past week;
- The temp gauge on the dash is sitting a little low, a couple marks below halfway...during a heat 🔥 wave of weather;
- I pulled a code and then cleared it (it popped up right after they ghosted up my vehicle...) and I maybe wrote it down incorrectly because the o'reilly's said they couldn't find the code, which I wrote down as p060. So, I'll wait for the CEL to pop up again and recheck it;
- I was low on coolant...during a heat wave. Coolant added. I'll hope it feels better tomorrow and get it in for all that asap.
There is a digit missing from the code and maybe the letter is wrong. Error codes are in hex, so there might be a letter at the end. like P060D.
The fan should only run after shutdown if the temp is over 240F.
Something is wrong.
Something is wrong.
- The fan stays on after the vehicle's shut off... for about 10 minutes, give or take 5? I didn't think much of it because of this heat wave for the past week; It's running above normal temp if the fan stays on after shutdown.
- The temp gauge on the dash is sitting a little low, a couple marks below halfway...during a heat 🔥 wave of weather; Temp gauge on the dash is not very accurate on these cars. Get the actual temp from the digital gauge in the DIC.
- I pulled a code and then cleared it (it popped up right after they ghosted up my vehicle...) and I maybe wrote it down incorrectly because the o'reilly's said they couldn't find the code, which I wrote down as p060. So, I'll wait for the CEL to pop up again and recheck it; Yes. You probably wrote it down wrong.
- I was low on coolant...during a heat wave. Coolant added. I'll hope it feels better tomorrow and get it in for all that asap. Coolant doesn't just disappear or evaporate. You have a leak or it's burning it out the tailpipe.
