P060?
Old 06-10-2021, 11:12 AM
  #31
MN Murph's Avatar
How about rechecking that live data with 2000rpm instead of idle?
But the low voltage is showing on the scan tool, while the engine is running.
Would bringing the rpm's up or letting it run longer give a more accurate reading?
MN Murph is offline
Old 06-10-2021, 03:48 PM
  #32
Lonwane's Avatar
I believe it's called a LOAD TEST.
Lonwane is offline
Old 06-10-2021, 05:20 PM
  #33
My thinking is thus: if the ECM is broken and the ECM controls the alternator;
The computers are supposed to be able to operate on 10V, there are a lot of reasons that less than 10V gets to them even with a full battery.
The output of the alternator varies, it is not a constant 14.4V.
A slightly low battery usually manifests more as a failure of a sensor on the 5 V ref first, not the ECM.
QED : it is not the battery being slightly low but the ECM.
Yes, this is donbrew blaming the computer.
donbrew is offline
Old 06-10-2021, 06:38 PM
  #34
Thanks for the explanation, Don.
RJ_RS_SS_350 is offline
Old 06-11-2021, 08:49 AM
  #35
MN Murph's Avatar
I found an 08 2.4 at the salvage yard. Is it worth trying to get that one's pcm
You guys thinks it's worth making a run to the salvage yard to grab a PCM out of a matching make/model/trim HHR?
MN Murph is offline
Old 06-11-2021, 09:39 AM
  #36
Sure, why not! ? Maybe, try trickle charger on the battery and clean the posts!
Oldblue is offline
Old 06-11-2021, 11:13 AM
  #37
It will need to be programmed to your VIN. Are my posts showing up? I gave some links for programming way back in post #17.
donbrew is offline
Old 06-11-2021, 11:25 AM
  #38
MN Murph's Avatar
Salvage yard parts Center asked for the part number of my PCM to match it to
This salvage yard has a parts store attached to it, stocked with salvaged parts. So I called them up cuz they got some for between 35 and 50 dollars online. The fella asked for the part number off mine. So I went to try to find it, and I don't know what I should and shouldn't touch or take out. How do you pull the PCM out and look at the number??
MN Murph is offline
Old 06-11-2021, 02:03 PM
  #39
MN Murph's Avatar
Closure to the battery question? 2nd test results
Originally Posted by Oldblue
Anybody notice ECU voltage is 12.2 volts?
dead battery , a dead battery!
Originally Posted by Lonwane
X2 on what Oldblue stated.
ECU volts at 12.264 is a dead battery.
Originally Posted by MN Murph
Is there a deep cycle test or just testing it in the vehicle that y'all are recommending?
This is a picture of the receipt.
Not sure if this helps bring any closure to the battery question. But I wanted to rule that out as a possible issue.
MN Murph is offline
Old 06-11-2021, 02:11 PM
  #40
Ok, thanks
Oldblue is offline
Quick Reply: P060?
