P062f
Old 09-25-2022, 01:19 PM
greg8453's Avatar
Call around and find a shop that can flash your system(s) with current software.
greg8453 is offline
Old 09-25-2022, 01:25 PM
https://store.allcomputerresources.c...ol-module.html
I suggest contacting them first.
A weld on the TCM , can I see photos of that, for further information
Oldblue is offline
Old 09-25-2022, 01:33 PM
Ren
Ren's Avatar
Welds in the bottom left hand corner
Ren is offline
Old 09-25-2022, 01:59 PM
Because the code does not apply to a specific module. Since you did the ground wire crap, I suspect the TCM. Do you have any of these symptoms?
BTW, you are misreading the meaning of the code. Semantics are odd. It does not mean THE control module has an internal fault. It means the ECM has detected an internal fault in a control module, usually the TCM.
Why and when did you do the facebook foolishness?
Look on eBay there used to be a few places that program a used ECM for around $100.
That is not a weld, it is where someone touched the module to the positive terminal. It is probably trashed.
donbrew is offline
Old 09-25-2022, 02:05 PM
Ren
Ren's Avatar
BTW, you are misreading the meaning of the code. Semantics are odd. It does not mean THE control module has an internal fault. It means the ECM has detected an internal fault in a control module, the TCM.
About two years ago for the stupidity
And no just long-term and short term memory fault
Ren is offline
Old 09-25-2022, 02:09 PM
The reason it is stupid is that it provides a perfect spot for a spark.
I was editing the post while you were typing, look at it again.
donbrew is offline
Old 09-25-2022, 02:11 PM
Ren
Ren's Avatar
Ya i agree it's trashed
Ren is offline
Old 09-25-2022, 02:26 PM
Try these, I have got one that was working and returned it because it wasn't my problem with no issue. Not sure it was this same guy.
ECM
https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
TCM
https://www.ebay.com/itm/20388121306...Bk9SR6ao-eHuYA
donbrew is offline
Old 09-25-2022, 03:37 PM
Check all three of The links Donbrew and I have posted.
Oldblue is offline
Old 09-25-2022, 06:10 PM
greg8453's Avatar
That looks like they ran a ground wire to it. You could ground it. It's will not hurt anything.
greg8453 is offline
Quick Reply: P062f
