? For Panel LS owners
Hello,
I bought a used 08 Panel LS.
The key fob has only 3 buttons but reading the owner manual says the 5 button key fob can be used to open the back doors.
Can I buy a 5 button key fob and get it programmed to open rear doors?
Does the LS have this feature?
Thanks,
Thanks,
Here is a link to a case and key pad that you could put your circuit into, pending your circuit board having the extra pads for the rear doors.
http://cgi.ebay.com/ebaymotors/2008-...Q5fAccessories
I have opened a few 4 botton fobs, and they had the extra pads.
I have an LT panel with the option, but don't know about the LS.
If you do have the option, I think you might need a dealer trip to get everything working.
Thanks Speedwagen for your tip,
I took my key fob apart and seen 6 contacts. Then pressed the would-be door buttons with the rubber fob part and the rear door popped with the remote.
I just need the shell like you said.
Thanks again,
Cheers!
Thanks again,
Cheers!
Allen S
Canadian North Pacific
0
11-02-2013 06:04 PM
GTOMIKE
12-06-2008 10:18 PM
