panel question
Old 05-21-2010 | 05:42 PM
pyro panel's Avatar
Former Sponsor
panel question
anybody know how to remove the two inner rear panels(the plastic pieces that fill where the rear window would be)they seem to be a separate piece but wondering if they are removable without pulling the whole inner panel assembly...
Old 05-22-2010 | 01:54 AM
Pyro-
no help here other than a "bump"
Old 05-23-2010 | 06:45 PM
blue car's Avatar
removed them about 30min ago sorry no pics .
heres what i did the top unit over the brake litehas 4 clips, its just a pull job and it comes right out. i started at the riders side pulled it off left to right... the larger unit has attached clips start from the top and work you way down. if you need to remove the whole unit you will find two snaps with a center plugs push in on this plug and it will come right out.... when your ready to replace just be sure you line up all the clips and its all good
milk_van
Mods - Exterior
10
12-30-2011 06:35 AM
Rikki Sixx
08-15-2010 10:54 PM
dpoll995
02-21-2009 03:28 PM
BennyBad
07-19-2008 11:01 AM
bonkers
03-28-2008 04:28 PM
