Passenger Inside Door Handle
Old 04-10-2023 | 03:49 PM
New to me HHR's Avatar
The time has come to replace the inside door handle on the passenger side. Seems like a common problem with our vehicles. Can someone recommend where to purchase the metal door handle and a procedure on how to replace it? I would assume YouTube would be a place to start but wanted someone with a first hand experience on doing this repair.
Thanks.
Old 04-10-2023 | 04:17 PM
https://www.ebay.ca/itm/155435835691...mis&media=COPY
And a how to video
Old 04-11-2023 | 08:15 AM
Ed ke6bnl's Avatar
I did not remove all that plastic just put in a new metal handle and new hindge parts(the drivers door is what I did)
Old 04-11-2023 | 08:32 AM
Then this is the video for that situation
Old 04-11-2023 | 03:21 PM
mister hhr's Avatar
Handle
I've had to replace both of my front inside door handles bought them off flea bay they were the metal ones I had a repair shop do the work for me.
Old 04-11-2023 | 03:30 PM
Instructions came with the ones I got. I left the circlip off thinking that gravity has been doing a good job for a few thousand millennia.
GM sells a handle now, competitively priced. I don't know what it is made of.
Old 04-24-2023 | 03:46 PM
Smile Task Completed
Thanks to everyone for advice, help and recommendations for replacing the inside door handle. I purchased the metal handle and replaced it this past weekend.
Old 04-24-2023 | 05:27 PM
PulpFriction's Avatar
I have a metal passenger side handle lying around, minus a the circlip, because I bought the pair and only needed the driver side. Good thing, because I lost one of the circlips when the wind caught the little baggie.
Pulling the door card off is harder than changing the handle. The single most important thing is to start with the correct fastener, the one on the rear of the door. Counterintuitively, you push the little center anvil IN 1/8" or so, and it pulls right out.
Fortunateson
01-01-2023 09:27 AM
LolaIsMyHHR
04-10-2021 07:19 AM
Cat Man HHR
08-01-2019 04:12 PM
Leeroy
Maintenance and Upkeep
11-30-2016 03:53 PM
ray5809
05-09-2012 01:11 PM
