Power window problem
Old 09-06-2020 | 03:01 PM
tack's Avatar
The rear power windows on my 2009 HHR LT stopped working. All fuses are good and I replaced the drivers door master switch. The rear window motors
are good because they work when jumped. There is no power going to the green power supply wire to either motor. Yes, I've tried the rear lockout control
on the master switch. On the wiring diagram there seems to be a junction where the green power wires meet. Any ideas on this? The fronts work fine.
Thanks.
Old 09-06-2020 | 04:48 PM
The green wire has been known for corrosion, you’re gonna have to follow that wire and find the junction and repair it.
Old 09-07-2020 | 12:52 PM
Cat Man HHR's Avatar
Where is the most probable place for the corrosion ?
Any proof or pictures for this ?
Wiring diagram would help.
Old 09-07-2020 | 01:13 PM
Post #77
https://www.chevyhhr.net/forums/www....ad.php?t=62806
Old 09-07-2020 | 02:07 PM
tack's Avatar
Any idea where the junction might be?
Old 09-07-2020 | 02:34 PM
See that was easy. Thanks.
Issue solved. If you recall only the drivers front window would only work . Turns out the entire issue was corroded wire at J323. No one mentioned this as a possible problem. For those who want to know it's in the wire bundle under the the carpet in front of the left front corner of the Drivers seat. This is the Dark Green Wire that connects to ALLthe windows. Hope this helps othes
Old 09-07-2020 | 04:38 PM
So, yes there is proof of this Catman, it was just posted on the 5th of September, so I decided to not include it in my post.
I don’t see how you didn’t notice that , or maybe you just like me or Donbrew or RJ to find information and post it for you.
There is a reason the search window was developed for this site.
In this thread post #1 it is stated no power to the green wire, there for it would warrant investigation of that wire for corrosion and or a break in the wire, a wire diagram is available on the inter webs , our search window connects to Google for this purpose.
Old 09-07-2020 | 05:08 PM
AND, Catman. If you're going to quote someone else's post, at least acknowledge that you did. Reason being. You put that quote in post #6 without any quotation marks so it looks like it's something you said and done..........Lots of confusion could follow.
Old 09-07-2020 | 05:16 PM
tack's Avatar
The corroded green clump of wires under the front left carpet was the problem. I cleaned up the wires and respliced them and now all windows work.
The area was wet which probably caused the corrision. Thanks for the information.
Old 09-07-2020 | 05:17 PM
tack's Avatar
That was the problem, thanks for the information.
