Problem with HHR
Old 04-28-2020 | 11:04 PM
Tye Weitman's Avatar
Problem with HHR
So I bought a 06 Chevy HHR LT 2.2 and at first when I started it it had a little metal rattle to it then it went away so I figured it was the timing chain so i opened it up and that's what one of my issues is the guide were broke and the tensioners were bad,the chain had slip in it so my next issue is.Is there a VVT system in a 06 Chevy HHR LT
Old 04-29-2020 | 04:59 AM
Cat Man HHR's Avatar
This is what is found on Wikipedia:
2009: Flex-Fuel (E85) was added to the 2.2 and 2.4 engines.[15] The 2.2 engine now comes with Variable Valve Timing (VVT).
Old 04-29-2020 | 06:20 AM
Welcome
If you had it apart to find all the timing chain problems, then you should have seen all the internal parts such as camshafts.
Didn't you notice that there is no VVT on that engine ?
FYI. The 2.2 used in the 06 HHR was a one year only engine. It was changed to different versions of the Ecotec engine in later years.
Old 04-29-2020 | 08:47 AM
Ed ke6bnl's Avatar
on the 2.4 there are solenoids on the top of the engine for the variable timing, are they on top for 2.2 with variable timing?
Old 04-29-2020 | 09:02 AM
All 2.4L are VVT 2009-2011 2.2L are VVT.
Old 04-29-2020 | 09:12 AM
No your 2006 HHR 2.2 would not have VVT. Did you change the balance shaft chain also?
Old 04-29-2020 | 09:15 AM
How is this relevant to a 2006 2.2 HHR?
Why post information not pertaining to the question asked?
Please answer the question asked . Then if you must add in the year of changes , but it’s still irrelevant.
billbryant
Maintenance and Upkeep
08-06-2019 10:52 PM
brcwolff
05-26-2017 08:34 AM
NappiiRoots
03-03-2017 03:07 PM
68Chrgr
14
09-11-2016 02:52 PM
han92
10-25-2014 02:23 PM
