Problems with her can anyone help
I must be misunderstanding.
You paid a Chevrolet Service department $250 to answer a question.
They never looked at the car
You personally replaced the fuse box under the hood and the starter.
I don't know what you mean emc.
What else is missing? Has anybody worked on the car at all?
You are going to need to learn how to use a DVOM and figure out some basic electronics
Okay the Chevy dealership replace the ignition and the shifter and I paid $250 for them to tell me that my starter was bad and fuse block was bad they were going to charge me $2,500 to replace those so I replace them myself when that didn't work I spoke to the guy and he said that my ECM the electronic control module was bad and I asked him I said how did you know that and he said that's the only thing it can be no one else has worked on this car .
Well I decided to look at my ignition area to see if there was something down there may be a loose wire that was causing the car to not start and I noticed that I have to burn wires to the ignition switch I'm wondering if this could be the problem
