Programmer for key fob
Old 01-03-2022, 10:36 PM
KArthur's Avatar
I have a 2009 LS and trying to get the key fob to work. Previous owner sd they had the ignition switch recall done, but after that, the fob didn't work again.
I put a new battery on the fob (CR2032) but that didn't help.
Has anyone tried these instead of the Dorman programmers?
https://www.ebay.com/itm/Car-Key-FOB...-127632-2357-0
KArthur is offline
Old 01-04-2022, 01:01 AM
guppy's Avatar
I would initially have my doubts as well, but the seller has 21 positive feedbacks for the fob programmer.
guppy is offline
Old 01-04-2022, 06:08 AM
Check the battery cage in your key fob, perhaps clean the key pad
Oldblue is offline
Old 01-04-2022, 06:16 AM
KArthur's Avatar
Did all that when I changed the battery. Going to take the fob by A/Z and see if even works. I think they have a tester.
I think the FCC# for our HHR's is KOBGT04A. This is listed in their ad so it "should" work.
KArthur is offline
Old 01-04-2022, 07:06 AM
Getting the ignition switch recall done has nothing to do with a fob not working. Must have just been a coincidence.
firemangeorge is offline
Old 01-04-2022, 08:33 AM
mongo's Avatar
I would ask myself how often am I going to use a fob programmer vs how much will the dealer charge to program the fobs.
mongo is offline
Old 01-04-2022, 10:42 AM
KArthur's Avatar
I thought the same thing when they told me that.
KArthur is offline
Old 01-04-2022, 04:44 PM
Same price as the Dorman, but no new fob.
donbrew is offline
Old 01-04-2022, 05:10 PM
You only get 3 sessions with the Dorman. The one that OP linked to (eBay) doesn't say if there is a limit. One review suggests that there is no limit. I would certainly ask the seller.
RJ_RS_SS_350 is offline
Old 01-04-2022, 08:38 PM
tsbrewers's Avatar
Buy an Autel AP200 obd scanner. You can program the fobs and then have a pretty descent scanner for fairly cheap. Main thing to know about this one is you get one manufacturer for free. So for example, if you use it on your HHR, you will be able to use it on any GM vehicle for free, forever. But if you decide to buy a ford you will have pay a yearly fee to be able to read ford codes, and so on, another yearly fee to read VW codes, and so on. For me, I have 4 Chevy cars in the driveway, so it was a no brainer. It will also do auto bleeds, and other things the cheapies won't do. It seems to be going for about $100 right now on amazon, but I paid about $55 or so for mine this summer, so shop around.
tsbrewers is offline
Quick Reply: Programmer for key fob
