Question from Germany
Hello dearest Chevy HHr town! I live in Germany and want to buy me an HHR. I have a question! Can I use the HHR a trailer drag! Where can I buy the device and what they like?
Can someone tell me next?
Rico
Rico
![Confused](https://www.chevyhhr.net/forums/images/smilies/icon_confused.gif)
Yes, but Chevy says only if you have the automatic transmission and a max weight of 1000 lbs which is about 453kilo
click on this to see how a hitch is installed http://www.tomshhr.com/index_files/page0003.htm
max. weight is the trailer and what is on it.
Sie sind immer hier willkommen! (You are always welcome to this site!)
Bestätigen Sie Sie haben die korrekten Gummireifen für Schleppen! (Make sure you have the correct tires for towing.)
Haben Sie einen großen Tag! (Have a great day!)
Herzlichst (Sincerely)
MWG2
MWG2
Thank you for the warm welcome
Thank you for the warm reception here at your home. In Germany, there is the HHR only been this year and not immediately. Did me a buy in the USA and I am on this side have come. I think it is very beautiful. Are there things to be considered when buying a HHR should necessarily eighth! Where can I get a HHR not get so expensive! Which is better, 2.2 or 2.4?
Rico from germany
Rico from germany
Ja, es ist ein schönes Auto. The 2.2 and 2.4 are about the same, the 2.2 gets better gas mileage but not by much. .The 2 engines are about the same except the 2.4 cost more to buy. Most people will say the 2.4L has more passing power. Didn't understand what you mean ---when buying a HHR should necessarily eighth! Write that in German and I'll see if I can translate it
Wo wohnen Sie in Deutschland?
Ich bin mit einem traslation Seite, da ich nicht sprechen Deutsch.
http://translate.google.com/translat...ngpair=en%7Cde this is the translation site I am using
Roy (East of Cleveland, Ohio)
Es ist eine Sache von opinon.
Ich bevorzuge den HHR 2LT mit den Seitenluftsäcken für die additonal Sicherheit.
2LT kommt auch mit Antiblockiersystem-Bremsen und Stabilitätskontrolle, beiden ausgezeichneten Sicherheitseigenschaften.
2LT kommt auch mit dem 2.4 Motor.
Sie sollten eine hintere Schwanken-Bar für die zusätzliche Fahrstabilität hinzufügen.
Hoffnung ist das nützlich.
-MWG2
_________________________________________
English translation:
It is a matter of opinon.
I prefer the HHR 2LT with the side air bags for additonal safety.
The 2LT also comes with antilock brakes and stability control, both excellent safety features.
The 2LT also comes with the 2.4 engine.
You should add a rear sway bar for added driving stability.
Hope this is helpful.
-MWG2
