Rear Cargo Shelf
Old 09-29-2007 | 04:00 PM
gunner6165's Avatar
Rear Cargo Shelf
My local stealer has been no help with this, so I'll ask the experts. How much weight have you guys and gals put on the rear cargo shelf?
My reason for asking are two. One is a 80 lb male greyhound, and the other is a 55 lb. female treeing walker coonhound. The greyhound does NOT fit well in the Jetta by himself, let alone if I had to bring my 3 yr old son with me. The grey doesn't like uneven surfaces to lay on, and if I leave the cargo shelf at the lower spot, it'll be level with the rear seats when folded down. I just don't want to find out after the fact that he's too heavy for that shelf. The coonhound isn't as big a problem, but she does deserve a nice place to lay down while in the vehicle, on the rare occasion she decides to lay down while in the vehicle.
Thanks for the info.
Dennis
Old 09-29-2007 | 04:09 PM
Brewer13's Avatar
Well, you don't necessarily have to put the shelf in the holders, let it lay flat across the bottom.
Old 09-29-2007 | 04:15 PM
I haven't heard of any weight tolerance for the cargo shelf.
I do know it can withstand more weight in the primary spot, than in the upper level.
Old 09-29-2007 | 04:30 PM
Snoopy's Avatar
I agree with GDZHHR.....
If it's any help, I put two 80# bags of concrete on the shelf (side by side) in the lower position.
Old 09-29-2007 | 04:34 PM
shaginwgn's Avatar
I have had 24 cases of bananas in the hhr, if I remember correctly i had around 10 or so in hatch part. Each case is 40lbs, you should be fine
Old 09-29-2007 | 04:35 PM
1Panel2NV's Avatar
You were the seventh member and this is your first post?
Old 09-29-2007 | 04:38 PM
enri9267's Avatar
I've just hauled 32 wall paver, with no problem. Just my back...LOL
Old 09-29-2007 | 05:03 PM
That's a LOT of lurking!!
Welcome to the land of posting!
Old 09-29-2007 | 05:18 PM
stick's Avatar
Just happened to be looking at mine today, planning for a sub box, and saw a sticker saying 250 lbs.
Old 09-29-2007 | 06:03 PM
Z-Man's Avatar
way to go stick.
Thanks
