Rear fender paint problems
Old 03-09-2014 | 09:51 PM
jimmycrook's Avatar
Back towards the end of January, I purchased an '09 HHR out of North Carolina. We have had a pretty harsh winter here in WV. Recently I washed my car and found that the rear fender area looks like it has been sand blasted down to bare metal. My HHR does not have the " running boards ". I had failed to notice that the passenger side, the side with most of the damage, was missing the clear plastic paint protector. However when I checked the driver's side I found that the 1/8" or so strip, below the plastic protector, was also down to bare metal. I realize these area's will require repainting, but how can I keep this from happening again? I can't afford to repaint my car every few months, or even every year. I really don't like the look of the " running boards ", and really don't want to spend the $1000 dollars it looks like it would take to install them, to install something I'm not really crazy about anyway. Any help is greatly appreciated!!
Old 03-10-2014 | 12:04 AM
The only real solution to keeping the rear fenders/doors from getting stone and grit blasted are running boards or mud flaps.
Since you're in the "no boards" camp give this thread on mud flaps a read.
Juust click the link below....
https://www.chevyhhr.net/forums/appearance-modifications-discussions-6/best-mud-flaps-30228/
Old 03-10-2014 | 12:21 AM
Fox Hat's Avatar
Sounds like you need some new Paint Protection Film or PPF.
Post your issue at the link with a few pics and someone will set you straight.
http://www.tintdude.com/forum/index....ear-bra-forum/
Old 03-10-2014 | 12:24 AM
Good point Fox Hat, after he gets the fenders sprayed he'll be needing new PPF regardless of the mudflaps.
The GM pn is 25791044 for the Left Rear Fender/Door
And the GM pn is 25791042 for the Right Rear Fender/Door
Old 03-10-2014 | 03:24 PM
could go old school and get the area sprayed with truck bed liner or roll it on , it can be tinted close to your color or left black, I have had this done to my old pickup on the rocker panel area to prevent road rash!!
Old 03-11-2014 | 10:31 AM
jimmycrook's Avatar
If I was to give in and go with the running boards, do I still need to invest in the PPF? What about the splash guards / mud flaps?
Old 03-11-2014 | 10:43 AM
Lucky's Avatar
From the factory if you have running boards the ppf is not required. The slash guards are optional but I would recommend them.
Old 03-11-2014 | 11:27 AM
Radco's Avatar
My 2 cents, is get the mud flaps at the very least.. IMO the boards look great buy they are not for everyone.. You can get a cheap set of flaps for around 30$ or the HHR ones like I have for around 60$.. And as mentioned have them put the paint protector on after repaint
Old 03-13-2014 | 09:02 AM
walkowg's Avatar
How about spray on color dip in clear spayed on only in the areas that you need . You can do it your self right before winter peel it off in the spring and then in the fall before winter do it again ??????
catdaddy137
03-08-2009 03:12 AM
Sunrise HHR
03-21-2008 06:41 PM
dvalin
02-20-2008 11:22 PM
BelizeBrian
01-30-2007 03:17 PM
66hemi
12-17-2006 11:20 PM
